Posted by MisterT on January 06, 2013 at 14:14:17 from (216.248.71.226):
In Reply to: Farmall H Carb posted by BobMFD on January 06, 2013 at 11:57:25:
If it runs okay with the choke 1/2 out, it is starving for fuel. Did you clean the screen behind the fuel inlet fitting? Is the sediment bowl under the tank clean? Is the shut-off on the sediment bowl open all the way?
It is also quite possible that the needle valve is partially stuck in the seat, even if you installed a brand new needle and seat. Smacking the carburetor with the handle of a large screwdriver will usually convince the needle valve to do its job properly.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
