Posted by Owen Aaland on November 28, 2012 at 18:40:41 from (216.47.35.187):
In Reply to: 560D swap posted by stock560 on November 26, 2012 at 18:48:55:
You could just use the crankshaft from the C263 to replace the one in the D282. The combine engine should be new enough that the crankshaft in it was used in both gas and diesel engines.
As far as swapping the engines all the rear parts from the diesel could be used with the gasoline engine. The diesel flywheel will work as long as you also continue to use the diesel starter. The front plate will have to come from another gasoline tractor engine as the combine plate is different because of the hydraulic pump drive on those machines. The front cover will have to be from either a 460 or 560 gas tractor. The front cover attaches to the top side of the frame where the later tractors attached to the inside of the frame. The frame rails are the same for both gas and diesel on the 560. Throttle linkage and air cleaner tubing are also different between gas and diesel.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
