Posted by Central Illinois on November 26, 2012 at 17:26:09 from (75.106.114.105):
In Reply to: 12 volt conversion posted by Mowdigger on November 25, 2012 at 13:00:52:
I converted mine about 7 years ago. I had the generator rewound to 12V, changed the regulator to 12V, put in a coil from a Kohler 12 h.p. engine with an internal resistor, switched the bulbs to 12V, switched the battery cables to a heavier cable and made the system into a negative ground. Because I switched polarity I reversed the wires on the ammeter and made for sure the coil had the negative side going to the points. Mine finally this last summer had the battery replaced. It has been trouble free. I converted a friends H the same way plus added electronic ignition to it. It starts as soon as the button is pushed.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
