Posted by Janicholson on November 20, 2012 at 18:09:16 from (96.24.99.126):
In Reply to: wide front shimmy posted by blunted on November 20, 2012 at 17:51:57:
Yes. Lift the tires off the ground one at a time. Spin the tire and use a nail or prick punch to scribe an accurate line on the tread. (requires a steady rest, like a couple of concrete blocks to hold the scribe.) Shake and wiggle the tire and spindle to find loose spindle or wheel bearings. Spindle bearings allow the vertical shaft to move in the spindle tube Now lower it back on the ground and drive it up gently against a 2X4 laid on the ground so both wheels are pushed rearward a little. Now measure that front to rear difference. using the scribe marks. It should be about 3/16 to 1/4" If more adjust the tierods to make it so. Now put the 2X4 behind the tires. back gently into it. Measure again. if the rear are more than about 1/8 inch wider in the rear than front with push on them from the board, there is too much slop. Either tierods, or spindles are worn. Jim
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
