Posted by Chuck H in Wi on October 01, 2012 at 17:32:34 from (75.241.172.24):
In Reply to: Cub steering posted by Steve Lambert on October 01, 2012 at 14:12:04:
Steve, there is a oil seal in that housing that probably need replaced as well, there is a thick spacer washer at the bottom of steering shaft that has to be in place in order to get shaft into hole in housing. You will have to turn steering wheel as you are installing and tap on end of shaft alittle.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
