Posted by P and R Pete on September 30, 2012 at 15:42:54 from (173.86.14.68):
In Reply to: 460 Wiring Harness posted by gearheadbill on September 30, 2012 at 15:26:12:
What timing!
Brillman.com
I just got a new wiring diagram for my FIL's 450, and it came with every wire a different color so it could be easily tracked, every terminal numbered, and a couple of sheets describing where every number should go.
See my topic 3 posts below yours. The order of the posts in my topic is messed up, but you'll be able to follow it. When I first posted pics of my FIL's wiring, there was a chorus that mentioned Brillman, and I wasn't disappointed. He's easily available by phone, too, if you run into questions.
What might be pertinent is if it's neg or pos ground, generator or alternator, voltage regulator or not, stuff like that.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
