Re: Farmall C charging system will not work
Posted by El Toro on June 13, 2008 at 09:24:56 from (64.12.116.73):
In Reply to: Farmall C charging system will not work posted by Greg 2010 on June 12, 2008 at 20:02:06:
Take a volt meter and check the charging voltage at the battery with the engine at 3/4 throttle. Should get around 7.2 volts on a 6 volt system. Hal
Latest Ad: Super WD9. [More Ads]
