Step 1 With it running at about 1/2 throttle, Use a jumper and ground the field terminal on the generator. Don,t disconnect abything, just do that. If it charges then, try grounding the regulator frame to the tractor frame. the ground must be good. If still no go, (with tractor off), Jump (for one second) between the Bat terminal on the VR, and the Gen term on the VR. This polarizes the gen field poles. There should be a substantial spark when doing this. Now try it. If no spark, the generator may be improperly grounded to the engine. This ground is also very important. If still no spark, the wire from the Amp meter may not be connected to the amp meter. Keep us informed, JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
