Posted by Brian Allen on September 30, 2012 at 14:03:02 from (142.169.215.28):
In Reply to: D3 engine noise posted by Tann1 on September 24, 2012 at 17:59:58:
As Old Magnet suggested, you need to pull the starter to check for damaged teeth on the ring gear, I suggest doing it before the starter destroys itself. A file should remove any damaged areas on the ring gear teeth that cause the starter to ride up (usually in one spot where the starter first engages the ring gear).
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
