Auction
Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: 555a backhoe
Posted by Roy Suomi on September 27, 2012 at 18:07:08 from (76.190.200.252):
In Reply to: 555a backhoe posted by kenben on September 25, 2012 at 16:38:21:
Under the machine inside the clutch housing , you will find a small steel plate bolted to the bottom.. Take the plate off and you will find a small steel ine with a plug in it.. This is the operating pressure of the directional reverser.. Install a hose and gauge into the line fitting.. This will tell you the transmission pressure .. With stabilizers down so rear wheels are off the ground and backhoe down too,I like to put jack stands under the back of the backhoe just for giggles.... someone can run the reverser while you check pressures.. If forward is much lower than reverse , that indicates a leak in the forward clutch circuit..Disassembly of the machine is needed if forward pressures are too low.... Loader blocked in full raised position , stands under loader front support.. Unbolt engine with axle attached . Be sure to use wedges between the axle and front support so the engine doesn't flip to the side..I use a good floor jack to roll the engine out..Sounds easy , but it's a little more work than what I described..
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Super WD9. [More Ads]
