Posted by LJD on September 13, 2012 at 19:38:40 from (75.194.226.36):
In Reply to: Roosa Master question posted by steve n carol on September 11, 2012 at 18:37:29:
The glass ball is part of the "housing pressure regulator." It keeps internal housing pressure at around 4 PSI. Running without it lowers the internal pressure to zero which in itself, hurts nothing. Plugging is an indicator of other problems - as you already know.
When the ball is plugged, housing pressure gets so high - it exceeds feed-fuel charge pressure and essentially shuts the pump down.
Probably all you need is $25 in parts to fix back to original, or for an extra $50 - you can eliminate that pellathane/plastic dampener ring.
By the way, that housing regulator valve also serves as an anti-drain back fuel check valve. When removed it can cause some equipment to get air in the fuel after sitting. Mostly a problem with cars and pickup trucks that have fuel tanks mounted far away from the pump and often sitting lower then the pump. Chevy had many cold-start problems in 6.2 and a few 6.5 diesels when that ball-valve leaked or got stuck.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
