Posted by just thinkin on September 13, 2012 at 05:48:33 from (74.34.80.133):
In Reply to: Re: Head gasket posted by Old Magnet on September 12, 2012 at 20:06:49:
The ring you are talking about is it a fire ring? That carbon ring may be a fire ring designed to keep the compression in the cylinder and away from the head gasket. Pinching head gasket material down on top of a liner that is not some type of metal is not going to prevent compression from leaking into water jacket. Case uses fire rings on their tractors. Gaskets come from Case without the rings and you must buy them seperate. Some after market Case gaskets have the fire rings in them. Make sure you have the right gasket as it sounds as compression is getting in water and the exhaust would make temp run high. Does it seem to be worse when you load it hard and the boost is up?
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
