Pity that after all the work you have done,did you check the bevel gear to pinion backlash,did the ware pattern look OK on both,usually a bad whine in reverse is caused by the backlash been either too tight or too loose,do you know the history of the tractor,sometimes the bevel gear gets changed without the pinion and as they are matched sets no adjustment will rid it of the whine if the gears are not meshing right,the steering clutch issue sounds like the friction material is worn off some of the discs and they are sticking to the driving ones and not letting go till the clutch is fully disengaged,then you can hear them grouch and let go abruptly,hope you can sort it without having to tear it apart again.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
