Auction
Re: Internation 175b torque converter trans issue
Posted by Dennis K (WA) on September 06, 2012 at 21:38:01 from (24.21.78.195):
In Reply to: Internation 175b torque converter trans issue posted by Tfphill on August 26, 2012 at 19:25:33:
Your pressures look normal when in neutral. They should stay about the same while in each gear. Try them in each gear at idle and reved up while holding the brakes. If they are close to the same you are good as far as pressures. You may not be able to hold the machine with the brakes in first low.
I think digging in a bank you may be limited to low gear but the machine should move about easily in the others. Digging in soft material like loose sand could problably be done in a higher gear.
If there is no sign of aluminum in your trans oil and no over heating of the trans oil, you are probably good to go.
You could easily check your engine boost pressure, intake manifold pressure, with a low pressure gauge. There should be a plug in the intake manifold to tap in the gauge. Check warmed up, in gear, stall the tracks and reved to hi rpm. Previous post has the spec. This will give an idea if your engine and torque converter are up to par.
I would be interested in what you find out.
We were in Barbados last December on a cruise and toured your area.
good luck
Dennis
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Super WD9. [More Ads]
