When you bleed the system did you see or hear any air coming out?? If you did, then you lost fuel supply to the pump. Crank the engine and crack the lines one at a time at the injectors. Also look for a cracked fuel line, or a sport were it is rubbing on something where you may have a small hole were air could get sucked in!!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
Looking 4 set 9 bolt hubs 3 1/8 inch to fit 60 to 4010 jd
[More Ads]
