Posted by NCWayne on August 28, 2012 at 20:12:47 from (69.40.232.132):
In Reply to: Dynahoe 190-4 posted by Erich Boehm on August 28, 2012 at 06:41:38:
If it has a lock valve in the line , and the seal on the piston fails it will do exactly what you are talking about. I just repacked an outrigger cylinder on a customers bucket truck that was doing exactly what you are describing, and a bad piston seal was the culprit.
It can go down because there is more surface area on the back side of the piston than the rod side (due to the rod taking up space). As a result of the extra space the fluid going into the cylinder will pressurize it enough to push it down, and displace fluid from the rod end to the tail end. There is just enough pressure differentialgoing that direction to make it move out and displace the fluid past the piston. Going the other way, because of the different size area the pressure has less area on the rod end to act upon vs the tail end, and unfortunately the displacement of fluid, and lack of differential pressure, keeps it from building enough pressure to cause the lock valve to unlock and allow the cylinder to raise.
If you need to get it up you can break the lines loose and use a jack, another machine, etc to put pressure on the cylinder in the up direction. This should unlock the valve and allow the cylinder to rise with the applied pressure, but it will usually drop right back down when the pressure is taken off of it, but at least the cylinder is no longer pressurized and can be removed to be rebuild. Good luck.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
