TractorLinks.com
Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem
Posted by AJ. on August 28, 2012 at 10:55:57 from (92.4.154.201):
In Reply to: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem posted by Chris up north on August 22, 2012 at 15:51:06:
If the machine has a good forward and reverse that suggests that the pressure is OK,the solenoid has to push the dump valve open to release the pressure,if that is not happening the most likely thing is 1 an electrical problem, 2 the solenoid is loose, 3 the solenoid has failed,check to see is tight, screw it on hand tight like a canister oil filter plus 3/4 turn, put two wires on to the pig tail,ground one and put power to the other to see if the clutch cuts out.
AJ
Name:
E-Mail:
Subject: Comments:
Optional Link URL:
Link Title:
Optional Image URL:
Optional Video Title:
Optional Video URL:
Email Notification: If you check this box, email will be sent to you whenever someone replies to this message. Your email address must be entered above to receive notification. This notification will be cancelled automatically after 2 weeks.
