TractorLinks.com
Re: Internation 175b torque converter trans issue
Posted by Dennis K (WA) on August 27, 2012 at 20:02:13 from (24.21.78.195):
In Reply to: Internation 175b torque converter trans issue posted by Tfphill on August 26, 2012 at 19:25:33:
You first need to check your filters. Are they clean? Does it look like they have aluminum in the oil? Aluminum would be from the converter.
The gauge on the dash is generally the clutch pressure (main pressure) not converter press unless some one has added one.
If I remember right the 175B had pressure taps under the floor plate at the front of the seat frame. One for clutch press, 180-220 psi, one for converter press, 80-100psi at hi idle and one for lub press around 25psi.
These would be 1/8'' pipe thread. If they are not there then you have to go to the press regulator valve on top of the transmission to tap in, also 1/8''pipe thread. This will probably require removal of the batteries.
Let us know what you find and we'll go from there.
good luck
Dennis
Name:
E-Mail:
Subject: Comments:
Optional Link URL:
Link Title:
Optional Image URL:
Optional Video Title:
Optional Video URL:
Email Notification: If you check this box, email will be sent to you whenever someone replies to this message. Your email address must be entered above to receive notification. This notification will be cancelled automatically after 2 weeks.
