Crawlers, Dozers, Loaders & Backhoes Discussion Board
Internation 175b torque converter trans issue
Posted by Tfphill on August 26, 2012 at 19:25:33 from (208.0.101.113):
Hello guys. I need some help with my 175b loader. It does not have pushing power. I have to use in low range 1gear. Works good in 1st but I think it could be better.
When put in second gear position which would be 3 rd or 4th high range the drive shaft to transmission stops turning when under very little load. When at idle drive shaft turns. The torque converter preassure reads good on gauge all the time. Any advice would be good.
Same happens when in reverse. Operates in 1gear and any other gear shaft stops turning.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
Latest Ad: Super WD9. [More Ads]
