Posted by NCWayne on August 25, 2012 at 19:35:29 from (69.40.232.132):
In Reply to: exhaust stack reducer posted by randal thornsbury on August 25, 2012 at 19:03:25:
Yes, Donaldson makes exhaust reducers. That said, a reduction from 4 to 3 inches is a big step backwards in the amount of cfm that can flow through the smaller pipe vs the larger pipe. Without knowing particulars it's impossible to say with 100% certainty, but in most cases a reduction like that will probably put too much backpressure on the exhaust system and cause at best a loss of power in the engine. If it's a turboed engine then it's for sure going to cause problems. Your best bet would be to spend the money to get the right size stack because not doing so could cost you alot more later on in problems with the engine like burnt valves, etc, etc.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
