I have not had to replace a single one,it is more than likely a wiring issue,with the engine stopped unplug the pig tail from the solenoid and connect a test lamp to the wiring,get a second person to press the brake with the key switched on,the lamp should light each time the pedal or switch is pressed,if not check that none of the circuit breakers has popped out, if they are OK the wiring may be chaffed or have a bad connection,you can test the solenoid by grounding one of the wires and touch the other with a hot 12 volts,you should hear it jump,keep the engine stopped while working on the machine esp the transmission as it can take off and run over someone.
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
