Posted by NCWayne on August 03, 2012 at 12:07:02 from (69.40.232.132):
In Reply to: Cat DH8 posted by Drew88 on August 03, 2012 at 10:43:03:
Even though it can be a PITA to check, and the turbo 'sounds; like it is working, that's where I'd start looking. I just replace a turbo on a customers machine a few months back that 'seemed to be working' and spun freely by hand and didn't appear to drag when spinning. Still my gut told me it was the problem and when the turbo shop tore it down they found the thrust bearings were shot and had been dragging causing the turbo to slow down instead of reaching full speed. Even a few thousand RPM'on the turbo can make a huge difference in the performance of the engine. Too, turbo seals leaking too much to the cold/suction side of the turbo can cause an excessive amount of oil to get drawn into the combustion chamber. A small leak will often go unnoticed as the oil will typically get burned off, but a larger leak will, in effect, flood the engine and will create black smoke due the amount of unburned fuel (oil and diesel) caused by the flooding. Either way the turbo would be my first choice to look at. Good luck.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
