TractorLinks.com
Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: Caterpillar Road Grader has no steering
Posted by DGH on July 29, 2012 at 17:49:13 from (72.25.192.4):
In Reply to: Caterpillar Road Grader has no steering posted by Provine Manor on July 27, 2012 at 18:38:59:
Why not take the gear box off and clean it up so you can see what is wrong. It is not that hard. Remove the big nut that holds the steering arm on, then support the bottom of the shaft with a heavy bar, then drive a big chisel in between the arm and the frame to pop the arm off the shaft. Then remove the two nuts at the bottom of the gear box and left it out. It is quite heavy so a hoist would be good. The shaft is in two sections with a coupling, the key may have sheared in that two!! There are alot of those old machines around so parts should not be hard to come by.
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
Optional Video Title:
Optional Video Embed:
Email Notification: If you check this box, email will be sent to you whenever someone replies to this message. Your email address must be entered above to receive notification. This notification will be cancelled automatically after 2 weeks.
