Posted by NCWayne on July 22, 2012 at 20:04:52 from (69.40.232.132):
In Reply to: Cat 815 brakes posted by Fritz Maurer on July 22, 2012 at 16:01:44:
What part of the brake chamber are you expecting to leak? I ask because I've built a couple of chambers on a CAT loader some years back and from what I remember about them the condition of the rod makes no difference because the only air pressure in the chamber is to the rear of the diaphram and not on the front side where the rod is. That being the case, the only reason air would leak around the rod would be because there is another problem internally causing the air to leak around the piston seal.
With all of that said, again based on what I remember about the chambers I rebuilt (the ones with a ring of bolts around the end of the chamber), the stoke on the chamber CAT uses is longer than the stroke on a typical chamber like your talking about using. However if you can find a chamber that will match functionality, stroke, and mounting dimensions, there is no reason that something other than the actual CAT part won't work the same as the CAT part.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
