Posted by jm. on June 30, 2012 at 20:10:30 from (75.105.64.53):
In Reply to: TD15C Engine Swap posted by Jeff Lowery on June 30, 2012 at 18:10:11:
Farm tractor swap is almost too easy. You will change the rear engine housing ,be sure to use your rear seal then depending on what tractor the intake ( intake on dozer is cast iron ) You will need to use your oil pan and again depending on what engine may have to change the front cover but all in all same block, The truck engine change requires fuel pump changes and a little more but have also used the short block from the trucks. Price of good running 466 engines has really dropped in the last year or so.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
