Yesterday's Tractor Co.
Shop Now View Cart
Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: D6c
Posted by NCWayne on June 21, 2012 at 21:01:32 from (
In Reply to: D6c posted by navyreteocs on June 21, 2012 at 14:57:58:
If I remember correctly on a 6C there whould be a suction screen for the transmission pump under the floor boards right about where your left foot would rest. You'll probably have to pull the floor pan to get to it but you should see a vertical canister with a square top and botton with a cover held down by 4 bolts or studs and nuts. Remove the 4 bolts or nuts, insuring you don't drop the spring between it and the filter screen. Pull the screen from the housing and seperate the magnetic rings from the filter and clean both items.
No guarantees but this might fix your problem. Anything beyond that will indicate excessive wear in the clutch packs that will require going into the transmission to repair. Good luck.
Optional Link URL:
Link Title:
Optional Image URL:
Optional Video Title:
Optional Video Embed:
Email Notification: If you check this box, email will be sent to you whenever someone replies to this message. Your email address must be entered above to receive notification. This notification will be cancelled automatically after 2 weeks.
