Posted by VicS on June 10, 2012 at 20:31:47 from (166.250.97.13):
In Reply to: Backhoe advice posted by Dave Panning on June 09, 2012 at 06:22:26:
Don't know how much you are willing to spend, so is hard to recommend specifics. When I was looking for a cheap farm hoe. 8000 dollars. I went to a used dealer I tractor pull with. He recommended I stay with a Case 2 wheel drive. Which he had none of. just Ford and JD. I ended up with a 480E Case.because it just weights 10000 lbs. can haul it on a 14000 lb. trailer and pull it with a single wheel pickup. It isn't very good looking but works good. I have repacked every cylinder, I think. and put most of the bushings in. My hoe also has a hyd thumb. wished it had a clam-shell buckett. Get one new enough to get a Cummins engine. They have 4 valve covers. almost last forever. Opinions are like belly-buttons, everybody has one. Vic
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
