to start off plug the drain hole at he bottom of the steering clutch chamber and st least 1/2 fill it with loose juice of your choice, many use diesel fuel with or without ATF added. It would be great if you have a month or so to run it around and really put a load on that clutch with the handle in the release position. It may or not break loose. The problem with pulling the final drive is that the brake drum has to slide off the clutch discs and that is usually solid rust. Many have to break the brake drum to get it apart.Used drums are available and used and new discs are available.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
