Posted by Roy Suomi on May 23, 2012 at 18:37:56 from (76.190.200.252):
Never again....Swapped out a Yanmar NTE-88 that was mistreated by a contractor for a Kubota 1903 ..Had to change/fabricate everything to make it work....Motor mounts , radiator, throttle bellcrank as the throttle worked the wrong way, change pump mounting bolt holes by 7 degrees, manual gauges , shut-off cable , oil cooler mounting , exhaust, air cleaner.Made an adapter to replace oil filter with a machined roundstock , drilled channeled and remote filter mount and hydraulic hoses....Kinda like building a hotrod.... many hours later finally done..Works well..Reason for swap as opposed to rebuild ?? Parts list was 3800.00 without doing the head and injector pump, starter.. Kubota was in an unused boring machine with only 40 hours on it....
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
