Posted by AJ. on May 10, 2012 at 08:07:27 from (92.4.158.212):
In Reply to: TD-9 diesel pump posted by valley view farms on May 10, 2012 at 07:53:47:
Remove the injector pipes from the injectors,put a squirt of fuel or oil into each fitting of the injectors,crank the engine over watching the injectors,you are looking to see if the compression is blowing back through one or more of the injectors due to a stuck nozzle,protect your face,if you have a blow back remove the injectors and have them serviced at your fuel injection shop. Good luck AJ
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
