Posted by LJD on May 06, 2012 at 05:04:31 from (75.213.55.13):
In Reply to: John Deere 350 posted by mccrash on May 03, 2012 at 19:48:42:
350 loader requires at least 800 lbs. in the back if there no rear attachments like a hoe or ripper. OEM 350 weight set was- four weights and two brackets to hold them. Each weight is 200 lbs. A used parts yard is likely to charge $1 per pound plus another hundred for the two brackets. Original set had three # 8255CU weights and one U20033 weight at the bottom.
350C loader uses the big single T33431
350C loader used one big weight instead of a stack.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
