Posted by NCWayne on May 01, 2012 at 12:07:30 from (69.40.232.132):
In Reply to: Re: Case 9030 B posted by BCnT on May 01, 2012 at 08:29:20:
Hadn't thought of that one even though I ran into one about two weeks ago that had a similar problem. In that case there was a broken ring terminal where the safety shutdown circuit wiring connected to the oil pressure switch. Terminal was broke and had almost worked it's way out from under the screw to a point that there was just the tip of one end still making connection. It was passing just enough power to keep the solenoid open enough for the engine to run at an idle but bog under a load. Put a new terminal on and tightened it down and the engine went back to running normally.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
