Posted by LJD on April 26, 2012 at 05:15:42 from (75.213.78.137):
In Reply to: Using Oliver OC-4? posted by 1970-1655 on April 26, 2012 at 04:54:42:
I've got an OC4 dozer and OC4 loader. Yes they move dirt. It all depends on how fast you need to get it done and IF the crawler will hold together. Most engine parts are very hard to find for OC4s since those Hercules three-bangers are uncommon. Some have steering clutches and some do not. I tend to use for loading/moving dirt only when the ground is too rough or slippery for a wheel loader. Wheel loader works much faster, and a 4WD skid-steer even faster yet. OC4 is geared a bit better in low gear then its predessor, the OC3/HG series. Still fast though unless it has the optional aux. transmission. OC4 was avaiable with a two-speed "Slo-Lo" with high/low range, or a reverser called the "Travel Reverser."
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
