Posted by jm. on July 22, 2011 at 19:18:48 from (75.105.64.53):
In Reply to: TD8E steering issue posted by Rob R on July 22, 2011 at 05:07:41:
Rob wish I could talk to you. Would take just a few imutes to explain the system. The td8 does not have clutches as such uses a planatery drive system.. Any way what you need to do is about a 10 minute fix .. I will try and tell you here but is a little tricky. On the Right side squat down and look at the sprocket. Put your hand at about 2 O clock. Look right on back on the dozer frame. You will find a lock nut on a 3/4 square stud. Now the trick part hold the stud and back off the nut just a little. Turn in the stud 1 and 1/2 turn. Tighten your lock nut (WITHOUT LETTING THE STUD TURN) Should have you problem solved. If not post an e-mail I will contact you and give you a phone number. 25 years ih experience.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
