You can check a glow-plug by checking amp draw on each one. I don't know anything about your specific machine, but most draw 6-10 amps each. If bad, they won't draw any current.
As to cleaning injectors? I don't personally believe in any chemical concoctions. When diesel injectors aren't working correctly, it is usually due to wear - and no cleaning fixes that.
Pintle injectors basically can't get plugged. If you've got injectors with the multiple small injector holes - they CAN get plugged with carbon. When they do, it's hard enough to get them working again with hard steel injector cleaning-wires. I can't imagine any chemical working. When they plug, it's usually with rock-hard carbon.
Some diesel shops have expensive ultra-sonic machines to clean some injectors. Can't say if they work or not.
Injector nozzles are usually pretty cheap. If you have to go through the work of pulling injectors out, it's often well worth just sticking on new nozzle tips. Now, if you've got throw-away pencil injectors - you can't replace any part of them.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
