Have you checked the hydraulic oil level? Mine will shut down if it has a low oil level. I don't know if that's because the charge pressure drops or because there's a manometer there checking suction pressures as well... but check the oil first. I can't see why changing the oil filter will improve anything as it's a return filter and should not in any way effect the charge pressure. I'd have to do a bunch of research to tell you where those sensers are located because I've never had to dig that deep into the problem although mine does sometime set the charge light partially alight... indicating a partial connection somewhere inthe circuit... either a bad sensor or a bare wire somewhere.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally
... [Read Article]
Latest Ad:
Rebuilt Injection pump for J D 1010. Call or text for pictures or more imformation.free shipping.U.S. No core charge
[More Ads]
