If your steering has gone very heavy it means the pump is not working correctly, if you can spin the steering wheel around without it moving the wheels there is a problem in the orbital valve, the fluid coming out the breather sounds like a pump issue,ie relief valve stuck open causing the fluid to foam, take off the reservoir housing to gain access to the filter, with the filter out of the way you will see on the back end of the pump the relief valve, undo the cap screw and take the valve out, check the spring, see the valve is not stuck or any o"ring on the body of the valve blown,with valve clean and all seals good put it back, fit a new filter (Napa FIL 1323) fill with fluid and see how it goes. AJ
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
