You are looking at a tapered dowel in each end of the pin,when the dowel is driven in it expands the pin which is split out against the bore of the link,to get the pin out the dowels have to be removed first,if you have a tap clean the threads,use a suitable piece of high grade threaded bar to screw into the dowel,use a suitable sleeve or a socket over the bar,put on the nut and tighten it up,hopefully the dowels will pop out,when the dowels are out use a suitable punch and drive the pin out, see the picture below. AJ
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
