Crawlers, Dozers, Loaders & Backhoes Discussion Board
Hydraulic couplings on a backhoe?
Posted by 135 Fan on July 01, 2008 at 10:22:18 from (24.70.95.205):
I went to put the hoe back on my Cat. It was a pain because the hydraulic quick couplers had pressure on them and wouldn't couple until I loosened a fitting and let some oil out. I assume just from the hydraulics creeping that it's what's causing the pressure. Cat claims it takes 5 minutes to hook up. How can I set the hoe so it doesn't get pressure on the lines from creeping? Should the backhoe couplers be connected back together when the hoe is off the machine? I can't put the hoe right on the ground because the hoses aren't long enough. I shouldn't have to loosen a fitting and lose oil everytime I put the hoe on. Taking it off is easier and it's also easier to hook the hoses back together on the Cat when I take the hoe off. Any suggestions would be appreciated. Dave
Latest Ad: Super WD9. [More Ads]
