Crawlers, Dozers, Loaders & Backhoes Discussion Board |
JCB Starter Solenoid
Posted by Rob Buckley on January 29, 2007 at 14:32:03 from (212.159.88.53):
The starter motor on me Perkins 4.236 powered JCB 3CX is giving me jip... Anyway, after sitting for a few months while I fixed the radiator, fired the old girl up (with the aid of a jump start) and it ran fine. Stopped, replaced the fuel filter and (jump) started again (battery not too hot & bleeding it all through took a few goes!). Ran it for a while to give the battery a good charge up, all's well with the world. Just be sure, thought I'd turn off and make sure it started again, before calling it a day. Turned the key, to be serenaded with an electrical 'bzzzt' noise...then nothing! Tested with a meter, the wire from the ignition switch to the starter solenoid was getting 12v when the key was turned, and 12v at the main solenoid terminal...but no starting action. Fast forward to yesterday, armed with a new solenoid I set out to get the machine going again. Fitted the new solenoid, connected it all up, and it (jump) started fine. To see how the battery was charging, I stuck a meter on the battery...voltage 12.44 volts. Same at the alternator terminals. Hmmm..... So, i turned off to See what happened next...and you guessed it, on turning the starter the same old 'bzzzt' and then nothing!! Tested with meter, still getting 12v at ignition switch solenoid wire. 12v at the 'input' terminal on the solenoid....when key moved to start, that drops to 0v, and all the time the start switch terminal on the solenoid is earth. So...my question is...what's going on???
I'm guessing the alternator is knackered, with a low battery & a voltage of 12.44v, doesn't seem to be charging. But why would it keep blowing starter solenoids? Is the starter kernackered too, or could a bad alternator be taking out the starter solenoid after a few mins of running? It seems to start fine with a new solenoid, but could get a bit expensive for every start!!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
Super WD9.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
