Posted by jdemaris on April 15, 2014 at 10:43:25 from (70.194.2.111):
In Reply to: JD Hyd Pump posted by Sako on April 15, 2014 at 06:37:48:
A pump repaired properly is not going to leak out the shaft. I'd put the blame on the place that did the work and not Deere. If it's leaking after 5 hours of use - why isn't the place that did the work making good on it? When I worked as a Deere mechanic - we either guaranteed our work - or - told the owner the part was too worn out to repair. If the pump housing is undamaged where the quad-ring and backup washer goes, and the shaft has no groove worn into it, and the shaft-bearings are adjusted properly - it is not going to leak.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
