Just a note here your crawler has the american bosch type A fuel pump when using a bosch fuel system you MUST use bosch injectors. The injectors look the same as the injectors used with the ih pump, but the fittings where the fuel line attach are different size same goes for the fuel lines from pump to injectors differenr size fitting then ih. The cap you speak of is the injection pump oil fill it should hold 3/8 pint of sae30 motor oil. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
