My quess is that if the engine starts good and doesn't miss or backfire, then your firing order is OK. Looks like all you did is move the plug wires one position and compenstated that by moving the timing gear in the mag. Once you get the tractor running as you want, then I would move the plug wires back so they are correct and change the gear in the mag to the correct position. Then next time you have to put in points or rotor it wouldn't be confusing. Al
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
