Thomas, Yes the No. 1 cylinder is the one in the front by the radiator. Then the timing would be 1-3-4-2. The cap on your injection pump is to add motor oil to the pump. Since you just got your tractor running, I would drain all the oil out of the injection pump and then re-fill it up to the level plug. This is a 1/4 inch plug up about 2 inches above the drain plug. You can use the same oil as what you put in the engine. If the pump was leaking, you might find that some diesel will drain out with the old oil. As far as the white smoke, it could be a bad injector or a valve not closing. Good Luck. Al
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
