While aj may be right I am inclined to think your float may be stuck in the carb. If you can pour gas in and it runs seems that gas is just not getting past the float. Pretty easy to check ,most of the bowls have a drain if not just remove the bowl and check for gas flow. In any advent if it runs when pouring gas you are almost there can,t take much to get it going. Just be prepared you will work on it as much as you run it if you keep it around.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
