There is the clutch play adjustment which is towards the inside of the housing--you pull back a sliding cover to remove the shaft to adjust. There is a 1/2 inch brake adjustment with a 1/2 inch set nut, this tells the brake when to start tightening, so if I loosen this the brake will apply later after the clutch disengages. The third adjustment is the brake band adjustment which is a 3/4 head to the outside and it should be tightened down and then backed off 1 full turn. I would guess that if I loosened this the brake would apply later.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
