That's like asking if a D6 is worth anything. You have to give a little more information or pictures or something! Typically Cat has very reliable transmissions. The 3204 isn't the best Cat engine but being it's a non turbo it will last a long time although known to have blow by with only 2 ring pistons. 931 went through B and C models. Later B models got an improved direct injection engine and added another track link as well as slightly higher lift height. Generally a 931 is a good machine and parts aren't a problem. Biggest concern is the undercarriage. New is readily available but not cheap if it needs a complete undercarriage. 931's are generally a good machine. Bob/Ont could give you the low down on what to check out.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
