Posted by Stick welding on December 18, 2013 at 22:59:45 from (96.53.210.246):
In Reply to: Re: hydraulic fluid posted by Charlie on December 18, 2013 at 06:52:13:
I think ATF is basically really high grade hyd. oil. It's used a lot for hyd. fluid in cold climates because it keeps the same viscosity over a wide temp. range and isn't as thick. I think it's 10 weight but maybe someone else knows for sure? It shouldn't be a problem if it mixes with a small amount of leftover fluid. They should both be petroleum based.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
