Auction
Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: TD 14 carb will not turn up engine rpms. up
Posted by n9lhm on December 18, 2013 at 13:02:14 from (38.111.252.2):
In Reply to: TD 14 carb will not turn up engine rpms. up posted by kurt f. cordes on December 17, 2013 at 22:03:49:
They don't run real fast at start. You should be able to maximize RPMs with the choke as it warms up, after it has run for a minute or so it should show full rpms with the choke fully open (800-1000 RPM or so). The throttle disc at the output of the carb can be set to change the idle RPMs, I believe the book spec is 7/64" clearance between the disc and the carb body. If it still needs part choke to run best after two minutes or so there is probably still a restriction in the carb jet. E-mail me back if you want to talk more. Brian
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Super WD9. [More Ads]
