What model Citroen engine is it,you say the timing is ok and that it's got a spark,what about gas,did you clean the carb,see that all the intake manifold is tight and the gaskets are good,if the manifold is drawing air it will not draw the gas,if thats ok remove the spark plugs,put a couple of cc's of gas in each cylinder and put the plugs back in pronto and try and start it,no ether,if it catches you will know its a gas/carb issue,a lot of Citroen engines have cambelts,they can strip the teeth but you would have checked that,do like Mike said above see the valves are working.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
